I just installed my gauge according to genos garage instructions using there universal fuel hose not much drive time yet but every thing seams to be working good i have 14 lbs pressure at idle 11 pounds cruising and 9 pounds wot.As of yet guage reading is steady no eratic movement.
  • Replies 4
  • Views 3.6k
Sound like your lift pump is getting weak... Minimum lift pump ressure is 10 PSI... I'm going to garther your running stock fuel lines yet so I would suggest you think about a Big Line Kit From Vulcan Performance. http://www.vulcanperformance.com/Draw-Straw-II-1-2-in-draw-tube-and-1-2-in-pushlo-p/vpps9804.htm
planning on either a air-dog 100 or rapter 95 up grade as soon as i can.
With the fuel pressure gauge present try and keep the pressure up as much as possible... You might want to add a dose of 2 cycle oil, biodiesel or similar to protect the Vp44 during low pressure moments...
Plus having a 5 psi drop in pressure is telling you the pump is not able to keep up with the demand. Baby the skinny pedal until you get your upgrade!
