Ok the last of the metal wire netting has popped under my driver seat and now I'm basically sitting in a lawn chair. Anyone have an ideal if theres a company making aftermarket seats? I've looked around but no one has is making a seat that will accommodatefor the built in seat belt. Has anyone delt with this proble yet?
  • Replies 24
  • Views 4.5k
Did my driver seat 2yr ago. Took it to a auto upholstery shop, The guy put STIFF memory foam in and reused the cover ! Now my a$$ stays in the truck and gets the same seat every time... LOL! Got real tired of feelen like I was sliden out!
Could be like Homer Simpson and put a bucket under the low spot and never have to get up to go to the bathroom. Lol.
The answer to the seat belt issue is a company that re-webs the seat belt mechanism.
Do a search online and you will find many results that either have a core and will send it with a core charge, or you take yours out and send it in.
This decision would likely depend on whether or not you want to drive your truck in the meantime.
But I have not found any aftermarket seat belts other than the basic floor or wall mounted cable and mechanism or solid mount.
Yes you can find a place that will re-web your seat belts, however, they are not cheap...
I'm going to have to take mine out & see if I could put some firmness back into my drivers seat. When I had my truck repainted 2 years ago. I had the seat repaired but it didn't last, cheap foam maybe.
A lot of the guys stuff pool noodles in the 80's Mercedes seats to give them some support, not sure if that would work in my situation or not.
Dave
