- Replies 9
- Views 6.3k
eddielee 3 posts
rlane547 3 posts
53Block 2 posts
Mopar1973Man 1 post
I recently went through the whole T/C lockup problem and found it to be a bad ground. I fixed the issue and no problems until today. It started going in and out of lockup in 3rd and 4th but not like it was doing before. Before it was at steady throttle now it does it at different throttle positions. Also I just got a P0336 code. My question is will a Crankshaft Position Sensor cause T/C lockup issues or am I getting the code because of T/C lockup problem?
