Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
I could use some advice on storing my truck this winter. Unfortunately I have to store it outside in the Utah winter. I put a battery tender on the batteries and that has worked well in the past.
The real question is the fuel. I have a 98Gal tank in the bed, which is out of the weather via an industrial topper. Should I fill up the tank? Should I burn out all the summer fuel and put in winterized fuel? Is there an additive I should put in the tank? What is the best way to take care of the fuel system while it sits in the winter? I don’t drive the truck in the winter because they use salt on the roads, and I want this truck to last until I am gone…..
