Ok guys my 2000 2500 cummins and now that its turned off cold ive noticed when cruising at 55 itll randomly just feel like i let off the throttle a bit then pick back up any of u guys had this issue and what caused it ive seen on here that the apps can cause this
Give the APPS a reset to see if that clears it up. Do you have anything to take live data? If you do you would be able to see the voltage on the apps go crazy. Do you have a fuel pressure gauge and an aftermarket lift pump? What PSI are you running?
