- Replies 4
- Views 3.9k
MoparFreak1988 2 posts
Mopar1973Man 1 post
cummins2k 1 post
Hey guys got a question for ya has anyone ever removed there crankshaft position sensor mine is right between the starter and the stock lift pump? My problem is that upon removal the factory service manual says to twist as you pull to remove it upon doing so the plastic housing disinigrated leaving me with a little quarter inch nub, any suggestions for getting this thing out without dropping the oil pan since I would need to drop the transmission to get the oil pan off, other than that I was thinking maybee drive a screw into it?Thanks in advance
