I had to share JAG1 handy work
While JAG1 was here we had him do some wood working. So I had to show it off...
Yeah I know I should had the picture while they were hung on the wall but... I was in the hurry...
  • Replies 6
  • Views 2.1k
Did he carve that?
No. MoparMom bought the 2 doves. JAG1 made the cross that they hang on. Orignally MoparMom wanted to hang it on a string in the living room on the stone fireplace. But the doves are so frail hat they need to be mounted to a wood backing so MoparMom wanted a nice wooden cross to hang them on. So JAG1 created the cross while he was here. That's a really good carpenter. He knows his stuff.
I had to interlock the crosses with Mikes old chop saw. It required perfect depth and width notches to interlock the crosses with worn bearings and dull blade. I got it though. One was a good pressure fit and the other had no play but fit together without much pressure. I just didn't a wiggle in the fitting together. It was some careful cutting running the material back and forth for a flat even notch.
My Harbor Freight chop saw... :duh: What do you expect???
LOL.
Looks like good work.  I'm not above Harbor Freight either.
