- Replies 13
- Views 7.3k
oldbeek 6 posts
Mopar1973Man 5 posts
jlwelding 1 post
JOHNFAK 1 post
Have set a code 0122 but the truck is running fine. Researching the TPS and it is not very expensive. What is the difference between a TPS with a harness and one without a wiring harness? Both listed for a 2001 diesel. Now to replace it. I think it is behind the housing with the cables that control the throttle. What needs to be removed to get to it? Last question is should I dive in and replace it and how do I reset the trouble codes?
