- Replies 16
- Views 11.9k
Wild and Free 10 posts
organicfarmer 4 posts
Mopar1973Man 1 post
AH64ID 1 post
Ok here is the skinny on my Smarty touch install with pics of where I stuffed things. I put all of the wiring and remote module in the open compartment of the left side of the dash where on some models there would be a fuse panel but in my case it was an open void just the perfect size for the touch components. There was an opening in the dash frame just the perfect size to get the OBDII cable end through and the other thing with the orange and yellow dot is the EGT probe hookup point which converts to the Touch module with another cable all of which wrapped up nicely and all fit in the cubby together.
I think the pics will be self explanatory but you can ask about the specific ones if needed.
