- Replies 6
- Views 2k
Local399 2 posts
Mopar1973Man 1 post
Wild and Free 1 post
Killer223 1 post
I am building my '99 2500 Shortbed 4x4 6 speed diesel into an Overland style rig. Not a crawler, but not a mellow desert truck either. I am looking at long arm kits, shackle flips, maybe going to 37s (on 35s now), need to regear and add lockers too.
As far as suspension I am looking at DOR stuff...trying to get minimal lift with maximum travel and I think DOR has that covered between the long arms and the shackle flip. Eventually I might do the coilovers but for now I will likely jut respring the front and use my fairly new Bilsteins.
I think I will do ARBs for the lockers...pretty darn pricey but it just seems to be the best strongest selectable lockers. I plan to put some road miles on this truck to get to e fun stuff so a selectable locker is kind of important...although an air locker up front and something more permanent in the rear might not be out of the question. I plan to add a compressor anyways, so there's that.
I think the truck has 3.55s. It is a 6 speed and feels like it tachs out a bit high to me so I wonder if someone put 3.73s in it...but either way I am guessing that 4.10s will be perfect for 35s or 37s to allow me to still get decent RPM at hiway speeds. Of course most lockers have a split in part number at the 4.10 mark...so if I had to run a lower (4.55s) I would have to get a new locker as well...so I don't want to screw this up.
So just kinda looking for any comments on my thoughts from the brain trust here. Thanks in advance.
