- Replies 11
- Views 2.2k
Mopar1973Man 5 posts
hex0rz 2 posts
Hawkez 2 posts
Buzzinhalfdozen 1 post
Man, pull a 14k pound trailer and it'll help remind you of what you need to do.
Recently, I have not been as diligent on my maintenance as I should have been. Dunno if this is something by happenstance or a related issue.
This only occurs after the truck sits for a while. The truck cranks just fine, but right at initial idle, I get a stutter then after a couple seconds goes away.
I'm thinking I may be suffering from a leaky banjo tee? At the least getting air in the fuel lines somewhere. Thoughts?
Just seems ironic this happens after pulling my trailer. I was keeping an eye on egts and never saw it go more than 1200 momentarily.
I did at one point for some reason see my coolant reach 240. Although I have not checked for white puff of smoke not smell for a sweet smell or check oil or coolant. Shouldn't be a blown head gasket, should it?
Edited by hex0rz
