fuel module
Guess I need  to buy a complete unit. Sender/float is bad and also I tore filter trying to remove it. Wheres a good source for a complete unit. or should I just change out those 2 parts
  • Replies 23
  • Views 6.3k
I fixed mine! Pulled the sump out and reached inside, I could feel the float rubing the side of the tank. I loosened the ring on top and twisted the basket from the bottom until the float moved freely. Went and filled up and gauge is reading full!
