s300g slow spool
I have 2002 cummins 6 speed with 100hp ddp injectors and s300g 57 65 14 and it spools slow and smokes alot till it spools at about 1700 to 1800rpms then it clears up.
  • Replies 11
  • Views 4k
Welcome.
About normal with a 14 cm turbo. Any electronic fueling and or timing boxes. Edge Comp, smarty ect?
First off welcome to the forum!! Please go in and fill out your signature so we know EVERYTHING about your truck. We like to know every little detail so that we can help you.
As for the problem, are you stabbing the throttle or rolling into it gently??
The best thing I think you could do is try to buy a 12cm housing for it. That turbo should spool very fast!
Those 100's are definitely plenty to get that going. That's nearly comparable to a stock turbo but with a bigger exhaust. I have the s364 and I spool around 1700 with 7x10's a smarty, edge juice with attitude, and hotrod pump.. So I'd say you're just fine with the spooling factor.. Just got learn to drive it.. With any new turbo, your power band will change and you just have to figure out where it is
Hmm i have a 56/60/14 non gated and it spools just fine, no smoke. Slightly more lag than my 12cm but not horrible. I have 100s also.
We're do I go to do my signature I can't find it.
the resonance iam asking about this is I had dap 120hp injectors and the same turbo and the truck smoked less but now with the 100hp ddp injectors it smokes alot more until it builds boost
In the top right corner click your user name, then click the "my settings"
From there you will see signature on the left side. Just click and fill it in!
As for the injectors, I don't hear good reviews about DDP. Everyone says they are pretty smokey. If you go with DAP injectors (Which I personally like) go with the 125hp sac style.
Well I had a set of dap 120s and after 6months I had a broken spring in the number 3 injector. so I took my stock ones and had them redone with ddp 100 nozzels
when you say"had them redone" did you send them in to DDP Exchange or did you buy there nozzles and have diesel shop remount them on your body's??
Diesel equipment a Bosch rebuilder put them on and set pop pressures
