Fuel lubricity
Sorry if this is not the place to post this but I have found a chart with the latest fuel HFRR values with the addition of bio fuel.
Since most fuel stations will have between 2% and 5% biodiesel I thought this would be great info for us VP44 powered trucks.
I am having difficulty posting the chart if someone can help I will get it up asap.
  • Replies 105
  • Views 19.5k
Biodiesel FAQ's (2) (1).docI did  a little checking around on my fuel lines today. I have an AD on mine with Eaton H20108 fuel lines. They are nitrile and this is what i found on it from Eaton.
It appears from the FAQ that B-20 and below, while not good, that temp is going to be a major concern. Any one know what kind of temps the fuel can get up to in the lines?
If what I am reading about pump labeling if the pump is not labeled to a B number that it is supposed to be B-5 or less. It seems the plain labeled bio I have bought acts the best with the truck. quiet and good mileage results. But there still remains the fact I am not sure what I am buying and putting thru the truck. I am going to have to do a little rethinking on this. I found a couple of stations here with straight #2 and the price is the same. I would even entertain changing the fuel lines since the truck seems to like the blend. Bio compatible fuel line is not that expensive. The fittings would possibly cost more that the line.
Every state is different in labeling requirements at the pump. Some states have to label the level of biofuel used at the pumps regardless of amount and some are not required to label anything. Ohio is not required to label their pumps if the level is below B10, and the ethanol labeling requirements are even more lax than biodiesel.
From the little research I have done today the FTC has had regulations in place for labeling since 2009. I have been seeing them for a while but never paid much attention to them until recently. They appear similar in the five states I have been working around for the past 6 months. NC, SC, GA, TN, and AL
Dave you might be right on that. For some reason I thought B10 was the cut off but according to this site it is B5.
http://www.natso.com/blog/truckstop-biodiesel-pump-labeling-requirements-unraveled-
Not exactly an official page but seems pretty solid.
Kind of unrelated but for anyone that might be interested in ethanol posting requirements for your state here it is. They vary quite a bit.
http://www.fuel-testers.com/state_guide_ethanol_laws.html
What level of bio are you seeing that is the same as straight #2?
B2 and even B5 should be pretty close in price to regular #2 and shouldnt be a problem with your fuel lines.
The NATSO page is one I looked at yesterday along with many others. They did seem to agree on the labeling of B-5 or less not having to show the percentage. The one my truck likes the best are label like this. The ones labeled bio mass work fine but dont seem to run as quiet as bioblend. Not sure why.
Edited by dripley
Here in this part of Alabama they are all priced within .04 of .05 cents of each other. I would have to look closer at some of the labels to get a better idea.
After reading from Eaton's site on the fuel lines that I have the B-5 and less should be ok like you say. But they do say that the temps the lines are exposed to could accelerate degradation of the lines especially with B-20 or greater. I am not thinking the lines get exposed to the kind of temps they are speaking of, 125* C. .
Not to be rude but I have been saying this since much earlier in the thread.
Up to 5% biodiesel or renewable diesel does not require labeling.
Any idea as to what temp it takes to set that code? It would seem that the sensor that detects this is in the VP. Any idea as to what temp the fuel would be flowing thru the system? I would think the return line would be the warmest for sure. I have always been one to run my tank very low before refilling, especially on the highway. The return line on my AD returns fuel to the basket so on a low tank I am probably pumping some warm fuel to the VP at that stage. Anyway to read that sensor to know whats going on?
On my rig I have seen fuel temps as high as 180* F. About 150* F is common. Just out if curiosity I'll keep tabs on the data logger and see what my fuel temps become after several short trips and possibly a long one.
I would think the temp is monitored within the VP44 within the electronics cooling section.
Now as far as temps go I will check my book to see if the min-max values are listed.
Edited by Vais01
 I have seen what you are saying about the B-5 or less but also seen things like this from Oregonhttps://www.portlandoregon.gov/bds/article/160802 saying you have to label even B-5. It does seem to go both ways but most of what i have seen says you dont and some say it has to be labeled but no percentage shown if 5 or below. I think it is confusing at best.
how are you checking the temp?
Several links I have seen state not required but I am looking into it more.
I'm sure it's only a matter of time before some type of standardization is done.
Through my Quadzilla's data logger.
Yesterday I spoke with 3 Bosch qualified builders of VP44 pumps and the internal seals are all made up of viton and biodiesel has little to no effect on viton.
Cummins reps said the VP44 on our trucks as long as it is a newer rebuild can safely handle up to B20 without issue but it's recommended to use B10 or lower.
I'll have to dig through some books to find it.
I have gone through my books and several PDF files with no success of finding the mmaximum temp.
Mine is about 5 years old from Blue Chip with 133k on it. 2 stroke its whole life. Of the different bio's I have run the bio blend which is unlabeled for content has been the best. If the myriad of labeling crap I have read is right it is 5% or less and the truck seems to like it. I would however not like waking up one day and find the any of the fuel system rotted away.
