- Replies 12
- Views 2.6k
TFaoro 5 posts
Mopar1973Man 2 posts
Royal Squire 2 posts
CSM 1 post
I just ran into this problem but I'm pretty sure I know what happen in my case. What had happened was I made a trip to town and put my truck back in the shop and closed the door. Wasn't but a short time later I get a call to do firewood hauling. I pulled the truck out and set the A/C for MAX A/C and proceeded on hitching up the trailer. I start noticing the compressor pulling really hard on the engine and cycling rapidly. Thought that was odd I got back in the truck the vents were blow warm air. Compressor still cycling. Then I head the compressor struggle and then started venting freon. I knew then what was going on I shut down the A/C and left it off till I was rolling. I did open the hood and look and the fan was FULLY UNLOCK and barely turning. So what has happen the freon was preheated and pressure were to high and kicking out on the high side pressures till it got so high it was venting to protect the system (around 450 PSI).
After I was on my way and got coolant up to temp and the fan was partial locked now the A/C worked just fine the rest of the day. So now experiencing this and seeing post in the past about warm A/C at stops I wonder if the fan is not properly locking and keeping air moving and the high side is shutting it down. Another possible occurrence is using Quickie Can with the hose included those typically have a oil charge with them and it possible to over charge with too much oil causing that problem. I've seen where condenser coils are so packed with bugs that air doesn't flow and freon temperatures and pressure sky rocket.
Like today I took the time and fired up the pressure washer and slowly worked my way across the condenser, intercooler and radiator being careful not to get to close to the coolers.Today again it reached a 100*F here at my house. So keeping radiators, intercoolers and condensers cleaned is priority. So if your fan clutch is not locking properly to keep air flow moving the condenser will for sure get too hot and drive the high side pressure to trip the high side switch. So think air flow when the A/C is getting warm at stops.
