- Replies 12
- Views 2.3k
Mopar1973Man 4 posts
AH64ID 3 posts
vini 2 posts
hex0rz 1 post
Let me start from the beginning. Bought the truck 3 years ago with 77,000 miles on it. Now approx. 130,000. Six months ago (When all my problems started) Some jack#&! sole the NOx canister off my truck. truck ran fine with awsome fuel mileage gain. Of course the check engine light came on. No biggy. I'll deal with it. Then an upper console message. DPF full/ power reduced/ see dealer. Truck ran fine except pulling my trailer down the highway when I would hit a hill as the truck would downshift it would lose power. ( My truck is used every day for our business, and never leaves the house without a trailer hooked to it.) I figured the exhaust can wait until vacation time. I would do a delete. Three weeks ago the truck just lost power and started missing. I limped it home and called my diesel mechanic buddy. He put his scanner on it and told me all the codes for the exhaust. I already knew that. Then he said I have a #4 injector misfire. I did not see the codes since he was the mechanic not me. I did not know anything about injectors at that time. He removed the injector nozzle and said this is the bad injector. I went to Auto Zone to order a new one.(Holy &#$* are these things made of gold?) Now I found out what an injector really was. I will skip all of my learning process because you guys sound like rocket scientist to me. I replaced the fuel nozzle and injector with the help of the internet. (This is how I stumbled upon you guys) After all this work on my truck I started it up last week, and it is still misfiring. No change. I have to hold the gas peddle down to keep it running. I hooked a scanner I rented from Auto Zone to it this morning. The only code I am getting is the P242F. I already know that since I have about a 19 inch gap in my exhaust system from the missing canister. No other codes and the truck barely runs. I don't have a mechanic buddy anymore. I think he erased all the codes. I'm not sure. I have researched til I had to loosen the adjustment on my hat. I know I can fix this,but I am going to need some guidance. I don't know what to do next.
By the way I am going to be a diesel mechanic when I grow up. HaHa. Thanks in advance for the help!
