New BHAF options!
I currently am working with a manufacturer to have an additional BHAF filter option. This filter uses Donaldson's Powercore technology and has a capable flow rate of 1300 CFM while filtering the air down to a micron rating substantially better than stock.
I am currently in process doing heat soak and IAT temp checks and EGT checks at WOT runs, cruising, part throttle acceleration and transient boost speed from cruising to passing acceleration.
Next tank of diesel will be a fuel economy test to see if any improvement exists.
I will do my best to keep everyone up to speed.
  • Replies 201
  • Views 38.5k
  • I have seen several dealerships void warranty for anything aftermarket. That said a K&N WILL VOID POWERTRAIN WARRANTY. Seen this more than a few times. If and when I do buy a new vehicle I will pu
  • The problem is not just buckling, but sealing properly.  A small chunk of 4" exhaust pipe on the inside of the flange is the definition of "cheap insurance". An old tim
  • It's for guys like me that are always barely out of idle.
Air Filter Poll 26 members have voted
  1. 1. What would you use?
    • BHAF
      84%
      22
    • New airbox for new filter
      0%
      0
    • Full air box kit and filter
      15%
      4
Please sign in or register to vote in this poll.
I would like to see some numbers, and so forth.
Pricing?
Who makes the filters? are they long standing like Wix or Donaldson?
Detailed pictures, inside, out, etc.
Dimensions?
No word on pricing but the filter element is a Donaldson Powercore.
The vendor wants to see if there is enough interest in this.
Interest would be based on some specs
Price,
Size,
Published flow numbers,
and price.
I am interested now, but I am just like ever other stupid consumer, lets see some pics and details.
Price,
Size,
and price.
The filter flow rate for the BHAF I am using is 1300 CFM according to a gentleman I spoke with. There is the possibility that an oval filter would be used rather than the round filter and it flows 150 CFM more than the round filter.
Currently the filter I am using is 8 inches long, 8 inches diameter and has a 5 inch flange. The same element can also receive a 4 inch flange or 6 inch offset flange.
The oval filter I'm still digging to get the dimensions.
Just got off the phone with the vendor again and for a full kit including duct work, filter and all we are looking in the ball park of the 300 dollar range. If they develop an air box only to utilize factory plumbing thar would be in the 200 dollar range.
These filters again can last up to 100,000 miles with typical conditions, filter the air better than OE and the current BHAF options and flow much more than the factory air box and BHAF options.
The more people that respond the better so spread the word.
That means it does not fit the factory air box, correct?
$300 is a bit pricey..
Here is where I get mine at...
http://www.vulcanperformance.com/Big-Honkin-Air-Filter-BHAF-p/bhaf.htm
Is there going to be a filter only option? Being I would be tossing out the box for the winter time to get warm for the engine when the temps fall well below ZERO.
Yes that is correct. The factory airbox itself is a key restriction point in our trucks air system. Even though a factory element can flow neat 480 CFM of air the box itself can not ingest that amount of air fast enough to properly supply even the factory turbo which can suck down around 900 plus CFM of air. This causes some compressor inefficiency and additional heat.
It is a pricy option but will help those in higher dust environments and extreme conditions. I fit in that category for sure.
There is a just filter option also and is available for purchase. I will post that info here in a bit.
I'm sure they would give us some sort of additional cold air duct work that depending on location could be altered to draw heated air during winter months.
Edited by Vais01
Gents please hit the poll and add to this. I will be updating information such as part numbers from the vendor for those who want a BHAF only option.
Ok BHAF sizes and part numbers:
These filters are available through Volant and built by Donaldson for them. They use the Powercore technology for the best flow, filtration and longevity. They can be back flushed with low pressure air if in extreme dust conditions and are water and moisture resistant.
8" long x 8" diameter filters on all BHAF options. Flow rates are 1300 CFM and the powercore can filter the air too!
4 inch flange: 61504
5 inch flange: 61502
6 inch offset flange: 61508
300$ for a air filter is a large pill to swallow.
The ones in Mike's picture are around $89. That is more my speed but still alot more than the BHAF.
Now that I seen the part number... Here is what it looks like (61504)
The filter go for an average of 80 dollars.
300 dollars would be for the entire air intake kit. Around 200 for an airbox for the filter that would use factory plumbing.
Both options with the air filter included.
The filter alone is around the 80 dollar range. Still cheaper than replacing your factory filter 3 to 4 times to equal the mileage from just one of these filters.
Edited by Vais01
Better filtration is cheap compared to replacing rings or rebuilding an engine.
The added airflow is a perk too.
Edited by Vais01
We may be able to have them build air plumbing and a heat shield if that would float everyones boat. Could help with the dust and allow for cooler running temps while hauling heavy or in extreme conditions.
Edited by Vais01
Lots of comments. Vote too.
Just back from a long haul today. 240 miles.
Weather
Average Temperature: 95*F
Humidity: 23%
Vehicle
Speed: 65 MPH
IAT 125*F
EGT's: 650-700*F
Boost: 2-5 PSI
Standard BHAF
Now that I watch the IAT closely on the way home. I noticed some thing rather odd. Cruising at 65 MPH produced the coolest temperatures. Coasting down grades with exhaust brake off causes the IAT to rise as much as +10*F so I was seeing as much as 135*F coasting at 65 MPH down a 6% grade. Now of course exhaust brake will kick the IAT hard I can see easy 160-170*F IAT temperature rattling against the exhaust brake. Idling I would be right about 140-145*F. Climbing grades with 15-20 PSI of boost the IAT temp either slipped down 2*F or hold steady at 125*F.
Personally there isn't much to gain by enclosing the BHAF in a case.
Data Provided By:
ISSPro EV2's Gauges and ScanGauge II
