New Injectors Install
- Replies 10
- Views 2.5k
Hawkez 5 posts
Wild and Free 2 posts
dripley 2 posts
CTcummins24V 1 post
I changed the injectors yesterday, it was my first time doing that. For the most part everything went well, usless you count me dropping a screw driver twice
in between the intercoooler and radiator. While I was in there I adjusted the valve lash and that went pretty well. I took a picture of my cross over tubes, as this is the first time pulling them, I didn't know if this was normal. The o rings were all still in place but you can see how they had deformed and created a mess above their groove. Everyone of them were like this. The o rings themselves were all still in tact but in pretty bad shape, not sure how much longer they would have gone before I would have seen problems. I carefully cleaned them up and installed new orings.
After everything was hooked back up and began to bleed and prime the fuel system. I cracked my fuel line, and got nothing. I loosened the banjo on the return line at the IP and I got fuel pushing from there. I cranked on and off for a good ten minutes and never got anything fuel at the head. My batteries finally died so I will give it a second go this morning. I can't see fuel leaking out of any of the connections behind the VP44, I feel those connections are good.
Will it usually take this long to prime after an injector change?
I do appreciate the wealth of knowledge on this site. I had my wife iPad on my work bench and I was swapping between articles.
