- Replies 46
- Views 6.8k
CSM 17 posts
Mopar1973Man 9 posts
TFaoro 6 posts
Vais01 6 posts
On some start ups it will blow some white/blue haze (smells like oil) smoke for a few seconds as the EGT rises. Also, if I sit and idle for extended periods, like 5min, when i continue driving it will blow the same color smoke as soon as my egt rises above 500-600. Once it burns the oil out, it doesn't come back, and the truck runs the same smoking or not.
The truck runs fine, and uses some oil, but not much... Mabe a quart every 2500 miles at the most. i haven't actually measured it.
I am wondering if I am getting excessive oil going down my exhaust valves, and coating the exhaust... either from worn guides or worn seals.
I am going to have the rockers off soon for a head stud install, does it make sense to you guys to change the seals as well?
And anybody have a good source for a complete Injector & Crossover O ring and valve seal kit? I want to change the O rings as they should be set and are more likely to leak if reused.
