- Replies 49
- Views 19k
Cowboy 23 posts
Vais01 6 posts
The_Hammer 5 posts
TFaoro 3 posts
Loose nut behind the wheel maybe?
Who knows, but I'm rooting for ya! I'll know more once I get this head on. But even if you don't plan on porting, I would be really tempted to get rid of the lip on the inside of the valve seat. It
A vertical one yes, some people also refer to it as a drill press.
I blew my head gasket on my 12V'er over a month ago, and have been shaving away at the head since. I'm not going to pretend like I know what I'm doing, I just want to document what I've done. Some of these pictures arn't up to date, I'll update them as I get new ones. Taking pictures of this stuff have proved to be challenging.
First things first.
Now, here's a look at the factories handy work. Notice the difference between these two cylinders. I can't do any worse than that! Also note the horrendous lip around the inside of the valve seat blocking much needed air flow. Plus there is an excess of material around the valve guide.
And a stock exhaust port. In stock form they really arn't that bad, a slight lip around the inside of the valve seat, and the large area around the valve guide.
Here you can see the floor of the stock intake runner.
And then after some massaging.
And then for the actual port work, of which I'm not completely done..
Intake:
Exhaust:
I also did a number on the valves, including giving them some shine and grinding the seat width back to spec (1.5-2mm) mine were 2.5-3mm.
Edited by Cowboy
