iTrader Score: 0 reviews
WYOMING5.9ISB's Truck Pics
White/Bluish Smoke Problems help....
I have a 2000 Dodge 2500 With 160k I recently am having problems with it smoking on a light acceleration until about 30mph. It stops smoking until I let of the throttle at about 60mph. then the smoke just dumps outta the pipe. I tried a hard accretion and no white smoke what so ever. Even when I let out of the throttle no white smoke at all. I am not noticing my coolant level or oil lever changing at all either. The Mods I have are Smartys03 stacked with an edge comp box. airdog lift pump. 125D62/80 silerbullet.
White/blueish smoke help...
- Replies 35
- Views 6.8k
WYOMING5.9ISB 16 posts
Me78569 9 posts
Mopar1973Man 4 posts
dripley 3 posts
Thanks sir. I will give it a try and get back to you later
Time to stop running the engine, get an oil analysis to see how much fuel is in the crankcase and if it caused damage, pull the injectors.
I replaced them my self. It is quite easy to do. There is one o ring on the cross over tube near the end where the fuel line attaches and the other end just seats into the injector. The injectors have
