- Replies 55
- Views 9.7k
leathermaneod 25 posts
Cowboy 10 posts
Mopar1973Man 7 posts
Vais01 7 posts
Hi all,
While changing my oil today I checked up on my turbo health. It has had a slight internal oil leak since I got it as you can see. So I decided to check for play in the shaft and it has a little bit. Nothing major, no metal shavings in there, but it has some play. How long can I keep running this thing? Truck is mainly just a DD right now. Also can it be rebuilt or does it have to be replaced? Can anyone recommend a rebuild kit or good a replacement turbo? I don't plan to make crazy power so I don't necessarily want to upgrade unless someone has a really compelling reason. It is for the truck in my sig.
I am also curious about this.
Clearly that is some very fine metal wear and it was caught on my magnetic drain plug from Geno's. Is it anything to be concerned about?
