No Defrost?
Well I`m driving home this evening and realize that my vents are not changing status, and I can`t get into defrost mode.  It seems like I have read before about 3rd gens having a notorious air diverter door? But I have no idea where it is located or how hard its going to be to get to.  Has anyone had the opportunity to deal with this before??
  • Replies 7
  • Views 5.9k
  • heater treater. they have videos on how to fix. http://www.heatertreater.net/magento/dodge/ram/02-08/dodge-ram-02-08.html
  • Wild and Free
    Wild and Free
    No vacuum controlled anything on a 3rd gen all electronic.
  • The problem turned out to be the axle on the mode 1 door was stripped causing all the air to come out the front vents. The recirc door was stripped as well, but I think that has more effect on AC in t
I went back and looked at some archives and found another member with a similar issue.  the air blows out of the front of the dash only, very little if any going to the floor, or defrost. The temperature control seems to be fine.
After watching the heater treater videos I`m thinking mode 1 door is the issue, and possibly the recirc door as well.. I have been noticing a single pop sound coming from the passenger floor area for some time and always immediately following startup and drive.
Edited by angus
Mine pops too, I got all the doors and installed them. You might be able to remove the fan and reach in and move one door. The floor vs defrost is the worse one to have to get to I think.
When you take the radio bezel off you can see the servos and might be able to actuate the door from there. But it's doughtful. They all go through a power on self test. That's why you hear it pop.
Should be vacuum controlled for defrosters. Also, if you disconnect the vacuum it should default to defrost mode automatically. So if you can reach defrost mode that means something is blocking the door from swinging for defrost mode.
The problem turned out to be the axle on the mode 1 door was stripped causing all the air to come out the front vents. The recirc door was stripped as well, but I think that has more effect on AC in the summer.
I bought both doors from heater treater shipped to my door for about $180 bucks... Seemed a little pricey for what you get? But considering the alternative.. Its a pretty good deal.
Installation for these two doors wasn't too bad, just takes a little patience.
Our trucks have two blend doors which control temperature, and a mode 2 door that controls bias between the defrost and floor... evidently a mode 2 door failure will default to defrost which leads most owners to forget about this one. I may have to go back and do the blend doors later, but for now I`m happy to have a clear windshield.
