Hi, my truck is stored for winter. I need to rebuilt my trans. this spring cause last autumn I had a leaking problem at the inspection cover. The trans. shift Ok but in O.D I felt a little slippage . I was thinking of an oil pump seal or maybe the converter???? If someone can help. 47re transmission. just been rebuild 2 years ago by me but had a problem with a hose to the cooler. It disconnect and lost all the oil. After that the trans. run fine for about 1 month until I work on adjusting TPS and got this leaking at the cover!!! the shift become more strong like 1-2. like a shift kit after TPS adjust and before the leaking problem .. . I install a transgo diesel kit in my rebuild 2 years ago!!
What you think??? Sorry for my text and my english, I'm not so good.. Try my best
Thanks Francis
And new single disc converter at same time than the rebuild
Thanks Francis
