Trans leak...list of todo items?
- Replies 24
- Views 4.5k
Mopar1973Man 8 posts
Me78569 6 posts
jamman 4 posts
Sam53 2 posts
Popular Days
Personally spending about $5 a quart for ATF+4 I would look towards fixing the leak and changing the fluid in one shot. But, that's me.
Hi all,
I was towing my trailer today as I was looking at cars to buy. It is a nice, heavy 18ft trailer, but I was towing empty. I got back after pulling 150 miles and noticed spots all over the front of the trailer that could have been confused w diesel splash.
Crawled under and found that the leak is on the hard lines from the trans to the trans cooler, right at a plastic retainer clip about just above transfer case. Their is corrosion there, appearing that salt got held their and it corroded and swelled and today it decided to rub through or blow a pin hole. It is a healthy leak.
i pulled into parts store and bought some ATF+4 and funnel, topped it and came home since parts store looked it up and said it wasn't in stock. But I don't trust the kid, he found one line that was $92 and it didn't look just right and the truck has 2. I will try and use the part lookup tool when I get back to the house as I am working on my work iPad (ptooey!) and the tool isn't compatible.
so, I will be installing new lines. But what else should I do while I am fooling w it? It is a daily driver right now. 165k miles. I have never serviced it. Never changed the fluid, but it will be getting a good flushing over the next workweek! I know there are bands, but not much else. I run highway speeds(up to 90mph) and towing good work trailer w car or sometimes bobcat or small tractor. Should I still get in there and drop the pan and look to see condition?
All suggestions are appreciated.
I confirmed today that I must have a failed thermostat. Running 70-80 w trailer and I just barely raised over the first hash mark, which makes it 160ish? So I need to do a search on the tstat info.
thanks in advance!
