- Replies 30
- Views 8k
notlimah 12 posts
Cowboy 5 posts
CTcummins24V 3 posts
TFaoro 3 posts
You guys are just over here doggin on my higher HP build
You have to swap the entire turbo, it's not hard. NO mix/match parts. The HY and HX used different connections to attach to the center section and have different center sections. First pic is an
To be honest, there are times I wish it was all still stock aside from the fuel system upgrade and a small tuner like a edge or smarty. Though, when I reflash my truck back to stock with a smarty it
So I've come to my senses a bit thanks to @TFaoro and have decided that I need to cannibalize my fleet and throw the HX that's in my 99 into the 02 since that's the truck that's staying for the long haul. Now, with that being said, I do have some questions.
- Do I take out the entire thing?! (turbine & compressor housings n such?)
- I figure I should get a rebuild kit for the HX since I know it's never been done, anything else besides the basic kit DAP sells?
- Anything else I should look at changing or upgrading while I have it apart?
- Tyler I know you got yours all nice and polished when you did your rebuild, where/how did you do that?
