Advice on RV trailer fender
Last time out with the 5th wheel the right side fender decided to customize itself. I was wondering if any one else has had this happen and what they did or have an idea.
New replacements are $150 each which I think is a lot for molded ABS.  There is aluminum trim fenders for $90 each or rubber trim for $50 for two.  One other thought was take the other side off and have fiberglass copies made by one of my customers that glasses surfboards.
http://www.icondirect.com/keystone-5th-wheel-travel-trailer-fender-skirts-fs710/
http://www.trailer-fenders.com/tandem-axle
http://pacerperformance.com/products-footer/flexy-flares/universal/no-lip-side-mount/led-smoke-hi-5-cab-roof-light-kit-88-02-gm-style-detailDSCN0039.JPG
Edited by IBMobile
  • Replies 25
  • Views 6.9k
  • Nothing wrong with new blade either. Our store front installers cut all of there window mullions with miter saws and the blades last a good while. I have cut a lot of aluminum and brass with a skill s
  • I found out the original fenders were just slapped on at the factory.  The right side had a 1"+ variation between front and back, never noticed it before.  I found the center line between the axl
  • The floor grates for the trailer's heater vents were beat up so I made new ones out of the scrap. pieces.
I need some on mine. This would be a lot better than to new plastic fenders like what came on it. If you know someone who has a metal break you could just crease them a little near the roll for a little rigidity. I like them.
