- Replies 51
- Views 17.8k
Itaintez 17 posts
Mopar1973Man 13 posts
notlimah 11 posts
Sam53 6 posts
Well, injectors checked good, so I got a new vp44. While I was at it, I installed a set of RV275 injectors, replaced crossover tube orings, replaced the pushrod cover gasket , intake gaskets, return l
Idle Validation Switch or IVS. Pins 6, 2, and 1. Typically on a stock APPS the voltage with toggle these two switches. On a Timbo APPS the sensor angle is what toggle these two switches. Basically Pin
Coolant temperature. Idle is completely based off of coolant temperatures. So once the APPS set the IDLE IVS then the ECM software bases the idle speed off of coolant temperature. So colde
Newbie here so please be gentle. I have a 99 24v, 4x4 auto 134k miles that started idling at 1000 rpm's and has a miss to it. Happened out of the blue while wife was driving. Idle stays at 1k and misses unless put in gear. when put in gear, it idles @ 900 rpm and smoothes out under load of trans while in gear. Truck runs out great as long as its accelerating but when you let off throttle you can hear it miss. Fuel psi is 19 at idle with a air dog 100 lift pump. Truck is stock besides lift pump. Only code its giving is p0234 and I found waste gate stuck. All exh temps from exh man are within 40 deg f of each other. Iat, ect , and map look good on scanner. Batteries are 6 months old and test good. I have checked and cleaned grounds. I have a timbo apps about 1 year old. Truck doesn't smoke any out exh pipe. I checked for ac voltage and got a high of .030vac. Any ideas? What will make a cummins idle high? ecm? I have auto enginuity on my laptop to scan with. Please help!
Edited by Itaintez
forgot to add some info
