Replaced PS Pump, Now vacuum pump leaking
Replaced the power steering pump an all the pressure lines, Now my vacuum pump is dripping steadily. looks like I have to pull it all over again.
Any helpfull tips
  • Replies 8
  • Views 2.1k
  • Dieselfuture
    Dieselfuture
    My guess is that something didn't lined up perfect and old seal didn't compensate, this guy explainsit best and he sells parts. https://www.google.com/url?sa=t&source=web&rct=j&url=http://
  • banzaitoyota
    banzaitoyota
    Got the broken oil feed fitting out
  • To be leak free is good. I was for a while but not any more. Need a few days off to plug them.
Started removing everything again, sheared the oil feed fitting on the vacuum pump  off.
Should I replace the vanes while the pump is apart?
Edited by banzaitoyota
Spelling
Ordered vanes and kit from Genos Garage, got here the next day. Will update Thursday night, if anyone is interested....
Napa had the correct fitting in stock.  Vacuum pump and power steering pump successfully reinstalled.  Found my transmission fluid leak. I had replaced one of the hard line in Dec 14, it had a Crack on the ferrule where the rubber line connects. Napa ordered me a replacement under warranty.  For now I have a regular hose clamped to it. No more leaks!!!
