APPS low voltage p0122
- Replies 37
- Views 14.1k
Mopar1973Man 11 posts
leathermaneod 11 posts
Frankstein 9 posts
notlimah 4 posts
I honestly don't know if the airtex from Rock Auto is the same or not, but I would doubt it. If you don't have the original to know what voltage you need, I would guess you would just set it as close
Type in the @ symbol and wait a second and names will pop up. So if I type @lea your name will show up on a little drop down menu and you select what name you want and it'll automatically pop int
I peeled the wiper hub out of the rheostat to sho the IVS section and how i works. Look at the previous picture there is a set of wipers on both sides. On side is for the throttle value the other side
Hello guys, I've just returned from a road trip and check with my edge JWA trouble codes and found a p0122. I notice a change in APPS % . I set it and got 0% at idle but after around 1 month now I have like 3-4% at idle and when colder with intake heater cycle, its 5-7% idle and drop to 0% when grid heater is on, after goes up to 5-7% .. Now I'll try to disconnect the batteries and try to relearn the APPS! Can it be the APPS begin to get tired? I changed it 2-3or4 years ago (dont remember) with an APPS from rockauto!
If I need to change the APPS wich one do you recommend me? best for cheap!! or simply the best that will last more. Thanks
