AC not quite as cold
- Replies 99
- Views 17.5k
leathermaneod 40 posts
dripley 22 posts
Mopar1973Man 20 posts
IBMobile 15 posts
Dripply is right. The only time I've seen the low side pressure that high was 55psi @108° F. Tests in a Jeep have shown that @ 90° F a system can have a 75% charge in it with a low side of 20psi hi
Best done with the manifold gauges. Start vehicle, take pressure and duct temp readings. Open low side port very slowly and only slightly to discharge refrigerant. After short time (1-2 minutes) c
134A boils (changing state from a liquid to a gas) at -15.34°F. When the 134A is discharging from the can both the volume and pressure drops in the can when that happens the temperature drops also.
Hey all,
I noticed lately that either my ac is not as cold as it used to be, or I just hadn't ever used it when it was really hot (I normally use windows when my wife isn't with). Its still cool, just not ice cold. I have also noticed in the past that at idle my ac compressor will lock and unlock regularly. I was reading about ac issues now to try and see whats up and discovered that the locking and unlocking probably means my system is low on pressure. Now I'm looking for advice on how to deal with this. Should I try a do-it-yourself can from autozone? Ive been told in the past they are dangerous and not the correct way to service the system, but I've been reading and a lot of guys say they use them with great success. Is it worth a try or not?
