- Replies 18
- Views 11.3k
I was looking for the 3 letter acronym to see if you posted that you changed them
I'm not sure if this video will be of any help. Dodge 1999 RAM Cummins 5.9L NV4500 5spd. 2WD ABS sensor signal from the rear differential @ 6 Mph. (YELLOW) pin1+ and pin8- @ abs connector. O
No not really, you can remove the PCM. The body control module, abs, cluster gauge, ecm, still can talk to each other. There's just one problem: Bus Bias And Termination. The volt
My truck throws P0501 code as soon as it travels even a quarter mile at road speed, there are no other symptoms.
2002 Dodge Ram 2500 Cummins with 47RE auto.
This truck had the transmission rebuilt before I got it and one of the front wheel bearings replaced. I have replaced the other front wheel bearing and wheel speed sensor, the transmission speed sensor and the rear axle speed sensor(which causes complete brake failure BTW). I have also replaced the ECM. The ABS appears to work OK, as hard breaking on gravel causes pedal pulse. Does anyone know what the P0501 code really means? Is it a difference in one of the 3 wheel speed sensors or a difference in the transmission tail shaft sensor and wheel sensors? Also does the ABS module actually store codes or just send VSS to the ECM and it sets code. BTW the speedo is working well. I had a Smarty tune installed, but changed back to stock for test with no change. When I had the Smarty installed, I also changed the tire size to 30" in the ABS which made the speedo dead on. I talked to Bob Wagner @ Smarty and he doesn't believe it is an ABS or Smarty issue. Any help is greatly appreciated, as this drives me nuts.
