01 24V 5 Speed Box Stacking HELP
Hello All,
.      Been referencing this site for years and found many answers. Good job.
Heres my question. I bought an 01 with a Banks Big Hoss Wire Tap. I have a Flashpaq F4 here also. Will these units work together. I looked on the stacking chart for the VP44 and didn't see the Big Hoss on there.
  • Replies 9
  • Views 2.7k
Does the Big Hoss also plug into the MAP sensor and the data link?
Welcome to the forum! Great to have another member :thumbup2:
Does it plug into the TPS? The banks ottomind I installed in 2005 plugged the MAP and TPS. Did not know what the data link was until I got the COMP.
That is the same way mine connected. I only asked because I thought it help those that know how to answer your question. I cannot.
Ok. Haha. Hopefully someone reads this that can. Thanks for helping me get it out there.
If the big boss doesn't plug into the data link, you should be just fine stacking them. The flashpaq should control timing and low end fueling while the banks takes over on the mid to high end.
Thanks for the input. Is this a for sure good idea for a little extra power?  I am not a power junkie but I do haul trailer all the time. Just looking for a little more without messing stuff up.  I just put a new pump and 50hp injectors on it. Just looking for a little more than the banks can do.
Agreed that you can stack them.
I would sell them both and get a all in one setup though.  Stacking always seemed like a lot of "what ifs" to me.  Prob me being dumb but ya
I think you would be happier with a quad or edge.
