- Replies 11
- Views 4.1k
Me78569 3 posts
Travelall 3 posts
Cowboy 2 posts
Royal Squire 1 post
Popular Days
You could also go with a 47RH transmission. Then all you'd need is a switch for OD and lock-up.
On the '97's the PCM only controls the RPM gauge, maintenance required indicator, and check engine light. All the other gauges interface directly to there corresponding sensor. There's a
Hello all new to the site, probably the best I've seen out there. Anyways I'm dropping a 1967 Travelall onto a 1997 3500 chassis and drivetrain. Does anyone have a write up on what needs to be hooked up on the harness for the transmission to work correctly? Also someone told me about installing a rheostat? To help with shifting?
