Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI:
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 373.8k
  • Quadzilla Power
    Quadzilla Power
I am having no drivability issues what so ever. Just was trying to keep my cruise timing in the 17.5 to 18.5 degree range as stated in the v2 in depth tuning. Just trying to make a good safe tune to run everyday with decent mpg. Once it's tweeked to my liking I'll start on a safe tow tune.
Any idea as to why my boost tops at 27 psi? Can you see that in the data log? Do I need more timing on the top?
Edited by KMayborn
I would leave it in terms of timing.  the documentation is erroring on the VERY safe side, the timing isn't gonna blow anything up provided that it pulls once you get on the throttle.   If you want you can pull .5* from the 2k setting.
I would run this
Quote
fuel load timing:2
Low psi timing reduct: 1.5
Timing reduct scaling :100%
light throttle timing adv: 1
light throttle timing limit: 35%
1500:16
2000:17.5
2500:22
3000:26
max: 28
As for boost have you done a boost leak test?  you can do things to throw more fuel at it if need be, but I want to make sure we cover the bases.
@Maybornk
Looking through your logs I dont see TPS input great than ~%40 so I can't comment much on the psi only being 27 max.   Ensure you are going WOT.
Edited by Me78569
I’m still waiting to update my tuner. I’m waiting on a cable to come in the mail. So I’m on the v1. I don’t want to blow my head gasket or mess up anything else. I’m still unsure of the timing and the fuel stretch.  Besides and airdog 150 and cold air intake. I have a stock 2nd gen and stock transmission. Can you show me some tunes that would be good for me? I want some decent/ good MPG. But like to have a little smoke, I don’t mind that. Any help would be great. I am still new to all of this.  Thank you for your help.
Try this
Timing = 5
Fuel Stretch = 2000
TPS MIN = 0 (both can and pump_
TPS MAX CAN = 100
TPS MAX Pump = 70
Boost Scaling = 25
that should go pretty good.
I would run this
@Maybornk
it must not have data logged.
I will try the new timing you suggested. Since my timing at 2k is  safe I will leave it at 18.
I was just researching a boost leak tester. I will gather all the parts and see what I come back with. I will also make a few WOT runs and make sure I get them data logged.
Cool,
Do a good hard 0- 60 run and a good hard highway speed pull.
Oh and I do not have my warmup temp set. Any suggestions?  Also what makes you ask? Just curious. Lol
7 minutes ago, Me78569 said:
Cool,
Will do. What should I run it up to on the highway speed pull? Just max boost?
Edited by KMayborn
The warm up mode is debatable, but a good place to start would be at or around 140.  Really I would suggest that you do not do any dogging on your truck until you've seen the thermostat open.  Once you're up to operating temp you should be good to go.  That's my opinion and it's served me well for the last 250k and trust me I beat on my truck quite frequently.
I would run it up through the gears and maybe even into lock up (assuming you have an auto) just to see how it responds as you're accelerating.  Goal is to squeeze the most power out of your tune while being able to keep it clean.  @Me78569 and I have been working on a tool that should make this whole process easier.  Hopefully we can have it up and available here soon for the community to benefit from.
I gotcha. I normally fire my truck up and let it run for a few minutes in the am before I leave. Sometimes as long as 20 when I'm loading my truck with what I'll need for the day.
I have a 6spd so I'll row thru the gears and see what we come up with.
Thanks for for all the help @Me78569 hopefully we will get this heavy pig moving pretty good. Lol
@Carbur8tr I think this stuff is pretty easy to use it's just knowing what's safe or not is the issue for me. I don't have a lot of tuning experience at all but I'm very mechanically minded. I'm the kind of person who wants to know what kind of changes we are making and why we want to make them. Some people get annoyed with my questions but you guys are awesome. It must get confusing with all the different setups people are running. I get confused just trying to keep up with the threads. Lol
keep up the good work guys. Looking forward to become a valuable member of this community.
Honestly it is pretty hard to hurt a vp44 truck with tuning.
As long as you are dropping timing into the 14-16* range when under 2k at heavy throttle, you are ok.
When in warmup mode the Quadzilla is using OEM timing, so I wanted to make sure the logs I was looking as was Quadzilla not OEM. Anything under 120*f ect will use OEM timing as well.
OEM timing will be very high when cold as well.
Gotcha. I will keep that in mind for future reference.
I think you either have a bad map sensor or your wastegate is opening randomly.  you are hitting 40 psi of boost but only for a few seconds then it comes back down to 26 psi.
I am gonna guess wastegate issues, note how boost jumps 3 times in the log
Alrigh, one thing to mention is that during this run I did have the egt defuel set to 1400. Could that have caused it to drop?
I will check out the wastegate and see what I can come up with.
Doesn't look like it.
I see fueling stable when boost climbs, but then boost just falls out.  I really think the wastegate is opening.
So, if I pull and plug the reference line to the waste gate it should stay closed correct? Just to verify it's the waste gate?
not if the wastegate itself is damaged.
Do you have a boost elbow installed?
Yes. It is turned all the way in.
FYI, once i know I can go over 40 I will set the tune to defule at 35 to be safe. Lol
Won't that also mean I need to drop my boost scaling to 35?
same thing,  I see boost climbing to 40 then dropping back to 27 without any change in the fueling or timing.  Still looks like the wastegate is popping open.
