Power lock
I replaced my door panels and the window motor on passenger side of my 1999 3500. Now my power locks don't work and I can't figure out why!  Any suggestions?
  • Replies 5
  • Views 1.9k
Possible you knocked a connector off of something. Pull the door panel and look around in there.
You probably don't have the switch plugged in all the way.
I'm a dumb a
Fuse was blown.
Welcome to the world of :doh:. You have a lot of good company.
Funny but true.
The previous owner of my 1996 Dodge Ram 1500 blew the fuse for the cluster lighting so instead of replacing the fuse he hot wired the radio illumination lead to another trigger so the panel light would come on. So during my time of replacing the head light switch I wanted to get my panel dimmer working again. So I replaced the fuse and cut the hacked wiring out and now it all works correctly. It amazes me how much people can screw something up electrically. :spank:<- Previous Owner
