Idle switch installed, no high idle.
- Replies 18
- Views 3.3k
Mopar1973Man 6 posts
Sycostang67 6 posts
Me78569 4 posts
crf450ish 1 post
I put them in the garage, but here's one..
I went back to the dealer this morning to have the reflash checked out. I guess the first tech did everything except actually turn the high idle function on. After 20 minutes I was good to go, tried
I'm going to bet the flash wasn't done right. Throttle, brake, speed and transmission in gear (auto) will cancel the high idle. By chance did you do any APPS sensor adjustments for voltage? If so it's
I just got done installing my high idle switch. I went to try it out, but nothing happened, I waited for about 10 minutes on each setting as I know it's not an instant thing. I don't think it is the switch as I have a scan gauge and it shows the IAT and ECT values change with each twist of the knob and the TPS voltage was also reading 0. I took the truck in 2 weeks ago to have the TSB for the high idle unlocked, they said to bring it back if it didn't work, but is there anything else I should check before I deal with the dealership again?
