- Replies 5
- Views 2.2k
Mopar1973Man 2 posts
dripley 1 post
nd2xlr8 1 post
FatherV 1 post
01 24v would loose throttle and surge going down road so checked ac voltage and no issues there so put scanner on it and watched the graph and it was freaking out for Tps. So checked temp and it also freaks out on the graph on scanner when throttle cuts out. Went to install new apps and either no voltage at pin or reads 4.6 v on new sensor started truck and goes wide open
