ABS brake issue on 96' Ram 2500 4x4
Howdy all.
I've been having an issue lately the brakes on my 96" 2500 4x4. Sometimes when hitting the brakes the pedal will go to the floor and I can barely stop. It happens at random and the ABS light never comes on. Yesterday I unplugged the ABS and my brakes started working normal again. I grew up driving trucks without ABS so I'm not going to kill myself or anything with it being disabled for now. I would like to get it figured out though but I'm not sure where to start.
  • Replies 6
  • Views 2.2k
    Have you bothered to change any of the speed sensors?   Have you ohm tested the sensor circuits to be sure there is no broken wires?   Have you check the ohm value of the sensors t
    Ummm... The best I can say is stop by a part store and ohm out some new sensors. Fronts are like 1k ohms if I remember right.
16 hours ago, Mopar1973Man said:
Which version of ABS, rear wheel or 4 wheel ABS?
4 wheel.
Have you check the ohm value of the sensors to see if there is a issues?
Pull the sensors and check for metal shaving pile up on the tips.
I'll check everything you listed. Would you mind telling me what the correct speed sensor ohm value is?
I normally do a lot of research before asking questions and prefer to not ask for handouts but I've got a lot on my plate so to speak right now and really appreciate any help I can get :)
