Re-gearing for the Cummins
- Replies 6
- Views 4.1k
JAG1 2 posts
martinique78 2 posts
Mopar1973Man 1 post
Me78569 1 post
Popular Days
That's what I was thinking too, it doesn't really bother me that the RPM's are that high. I just know I could get better fuel mileage if I brought the gearing down. Yeah I did it all myse
Thanks! Lots of reading and knowing that the 2003 and newer dodges came with the same transfer case NP271/273. NP271 being the manual shift and the NP273 being the electric shift. Only thing differe
So i have been driving my Fummins Excursion for a few weeks now with no real issues. However on the freeway i'm turning some pretty high RPM's at 70-80. Like around 2700 rpm. At first I thought I wasn't getting lockup but I installed the lockout switch and an LED to show when the PCM was commanding lockup. all was working properly even without using the switch. So my next though was to check the door tag for the axel ratio...4.30!!!!!! holy crap that explains it. Now I know why from a dead stop that thing feels like it could rip the rear end right out from under it.
What would be a good ratio to switch to? I have the 2001 24V and the 47RE trans. I'm currently running 315/75/16 tires but I plan to lift the truck and run 36's on it in the future. Is it even worth changing the gears if i'm gonna be turning larger tires soon or is that ratio still too big for even that setup?
Edited the title
