Oil change interval question
Now I know this has been covered a lot, but no one could ever really answer the question I have. Figured I'd ask here since we have our own oil expert on board. I know the change interval in the manual says 7500mi. My situation in a bit different being my truck only sees ~ 5000 mi. a year. It is a work truck and I usually only use it to pull trailers and haul. It does not see a lot of highway driving either. I use Rotella 15-w40 and change twice a year or every 2500 mi. Can I change only 1 time a year and be safe? Should I go to synthetic if I only change once a year? Our mech at work is old school and still believes in the 3 month 3000 mi. thing. Some of the vans there may only have a few hundred miles on but still get changed every 3 month. I believe that is over kill as oil has improved a lot over the years but I don't know. Is 1 year too long? 6 months too long? What would you do?
  • Replies 27
  • Views 16.2k
  • Buzzinhalfdozen
    Buzzinhalfdozen
    With t6 and a good filter you can very easily run the oil out to at least 10,000 miles. I've done oil analysis out to 20,000 on t6 (filter change at 10k) and the oil was still in great shape. If you w
  • Best way is to contact Blackstone labs, and ask for a sample kit. Cost is currently $38 to analyze for extended changes. They will send you a report, and how long you may go. I did this and when
  • ideally you want to keep the oil changes at or around 500 hours. that's the spec for most modern oils. yes some can and do go longer. but 500 is the formula cummins recommended for the new trucks. 15K
So this might be stupid on my part but after doing head gasket I still haven't changed my oil, put almost thousand miles on it since. I now have 3500ml on the oil. I don't believe water ever got in oil and I do have a bypass filter. So I'll be changing it this fall when I get around 5k on oil. It is still half clean on dipstick, I do know if I put it in a bucket it will look black. Smells ok too. Screwed up part is I got 20 gal of new oil and like 8 filters, I guess I'm wired like that.
20 gal lol.
i have over 100 of travellers 15/40 and over 60 valvoline 15/40. and around 30 valvoline 5/40.
and roughly 35-38 of 5/30 supertech for my wifes car. i stocked up on the older CJ-4+ stuff when i had a chance. now i mix it about 50/50 with the newer CK stuff.
Why.. cuz i'm an odd one.
and as i said before, i change my oil's once a year. roughly 8-9K miles.
my next investment is a oil burner stove/furnace to heat the garage.
14 hours ago, dave110 said:
They make a little digital 12vhour meter for lawn & garden equipment that only costs like $25. I often thought of wiring one up in the truck but never got around to it.
But my question is TIME. 15 k miles takes me 3 years to accumulate. IDK, seems too long.
I may just do this. Do they give a recommendation on time too, or just mileage?
Just based on the number of miles on the current sample. I have every change tested, but only basic test which is $28.
Probably not a good idea, but I've done it myself on other vehicles
Why is it not a good idea? the CK is "backwards" compatible... so the way i see it i'm adding some of the good ol oil to the newer not so good oil, in order to make a half way decent oil.
this is the oil i run
https://www.tractorsupply.com/tsc/product/traveller-premium-all-fleet-15w-40-diesel-engine-oil-1-gal
no issues. we ran this in the tractors onthe ranch for years n years. the old massy still going strong.
I run that in my skid steer as well. I should probably just use it in the truck too, but I like that Rotella smell.
