- Replies 8
- Views 2.2k
dripley 3 posts
Mopar1973Man 2 posts
DocH 2 posts
Nekkedbob 1 post
Popular Days
This is a very patient place. I have learned a lot here due to that.
I still have the low warning light that I bought from BCD in a bag. Sounded like a good idea at the time until I learned about the importance of minimum pressure. I believe the BDP comes on at 5 psi.
Just wanted to touch base here and Say a Big Thank-You to Everybody!
Big Blue ran fine across county last Nov!
Pulled a 2 axle U-Haul across the I80 rte with out issues.
Arrived in Klickitat County, Wa. after 4 days.
Replacing the APS and alternator seemed to do wonders for the truck. The OSC radiator has performed very well,, even with the mercury hitting 112 here early this month!
Looks like We will be heading back east in Nov, with Our destination being the Pike County, Pa area. Hope to pull a 2013-14 Dodge Avenger behind us...
While I'm here, the lift pump pressure I installed last Summer is leaking out of the end where the wire lead hooks on...Anybody know the size of the banjo bolt that fits the input side on the VP44?
That sensor replaced the banjo bolt on the line that comes from the Raptor Lift pump.
I just do not remember the size of the banjo bolt....12mm sound right?
Thanks again All,
Ed
