- Replies 15
- Views 5.4k
Silverdodge 4 posts
jlbayes 4 posts
trreed 4 posts
notlimah 3 posts
If I were to stay with a single, I'd probably leave the current turbo I have. Plenty of low end torque due to the .70 housing, and has plenty of top end power. That's approximately where I am
Silverdodge, the 68 turbine is going to limit power to 550whp in a single turbo application on a vp truck. It is just where they seem to fall. Regardless of housing size. Notlimah, a 62/65
Because I can't mix and match with this charger as easily as I could with the s300 and I'd rather have an s300
I'm looking to dump the turbo I'm running for a step to compounds in the s300 s400 in the far future now I'm planning on going with an sxe 62 inducer and ether a 65 or 68 and ether a 12 or 14 exhaust side any opinions I'm planning on buying from apg
