- Replies 10
- Views 5.2k
Mopar1973Man 4 posts
uber racing 1 post
evans.mikey 1 post
Rogan 1 post
Just finished installing my custom built auxiliary fuel tank in the bed of my truck. I didn't like the cost or the size's of most of the units I've seen. Wanted something that would fit under the rails and not take up too much bed space. A buddy of mine own a fab shop and makes some tanks for some Bio guys. What we came up with was a aluminum tank made form .100" sheet. Measures 48"W x 17"H x 12"L. capacity is a reasonable 41 gal. Got the rollover valve from Jegs, and picked up an aluminum vented filler neck and cap assembly from an aircraft supply house I found on-line. We installed two internal baffle plates to control fuel slosh. we also welded on an external tray and tabs to hold my 6 gal water / meth tank. I have a filter pump from a Cat, but haven't installed it yet. I'm currently just using a gravity feed kit from RDS. I was actually suprised on how quickly the gravity feed with a 5/16" line will fill the main tank. It filled a 1/4 tank in about 15min of driving. I'll have some pics of the build and install in a few days.
