- Replies 9
- Views 3k
Matthewski89 4 posts
Me78569 3 posts
Mopar1973Man 1 post
kzimmer 1 post
Popular Days
Thanks, I will give that a shot. That 88 loves the fuel when it's spooled! Will have to test out your changes Wednesday I blew a 7ply boot apart today at 80lbs time for some more v bands
been doing a ton of reading and trial and error and having slight difficulties with my tune. i have a 99 cummins with a built 47re, fass 150 6x.018 sac injectors .093 tubes, stock lines, dragon flow 150% over pump. arp studs, 103# valve springs and extreme duty pushrods, and 67 / 88 compounds. ive got a good DD tune that has very minimal smoke, working on my track tune and on level 5 it will rev all the way to 4k when i put it to level 6 with 100% wiretap it cuts out at 22-2500 rpm sounds like its hitting limiter not sure what to change to make it pull all the way to 4k without cutting out like that any info would be appreciated
