Hi all... I discovered two cracks in my stock manifold. I have searched here and could not find too much...
Can someone recommend a replacement for me? I would like to put something in that I do not have to worry about again and perhaps something with a port already installed for my EGT probe.
I do not plan to add any performance upgrades... except maybe 75-90hp injectors down the road when these get tired.
Thanks in advance..........
Edited by dodgedieselnewbie
  • Replies 17
  • Views 3k
  • It is, but my compounds require the manifold to be flipped - and I had 2 EGT probes - 1 of which I couldn't string underneath. The only 2 SS bolts required for mounting it are included. The rest
  • dodgedieselnewbie
    dodgedieselnewbie
    Well.. it took me all day but it's in! I'm so sore.. lol   Had a difficult time with accessing the bottom forward bolt where the turbo connects to manifold. I ended up using one of the two s
I have a stainless diesel. Yes it is setup for stock location.
1 hour ago, dodgedieselnewbie said:
There are a ton of diesel stainless manifolds that range in price. I found this one that is one piece, has one port and comes with gaskets.. for best price I could find. This what you are referring to? Thanks again!
https://www.genosgarage.com/product/bd-1045985ss-kit/exhaust-manifolds
I have that one. It's a good manifold - just don't try to drill and tap it!
It looks to be already drilled and tapped, the only difference I see is unknown place of manufacturing and no ss bolts between 2 links. I kinda like the one made in USA.
The only 2 SS bolts required for mounting it are included. The rest can use the stock ones. For me, the stock, SS, and an aftermarket stud kit have all loosened up over time. I recommend high temp thread locker on all of them.
I did not see any mention of the 2 SS bolts. Where are those required?
As for the bolts.. whether the stock, all stainless or a stud kit. Should I change them out with new? If so.. which way should I go?
I just did a head gasket on my truck and all of bolts were in good shape so I reused them and didn't reuse the straps that keep bolts from backing out, so far it's good. I did have a tiny crack but decided to wait on changing it as I spent too much on HG job and head. In my opinion if both manifolds are good quality then get the cheaper one and reuse stock bolts. I would go with made in USA just because.
Thanks... but... $230 is a pretty significant difference.
Yes but, USA USA USA.  Lol I own some harbor freight tools. That's how we by sh.t at wallmart too and wonder what's happening to the country. I see your point,  if you bought everything made in USA, you'd be sleeping in a truck.
Edited by Dieselfuture
You might want to call and ask them to be sure. If I remember right mine came with 4 SS bolts. 2 are for the turbo, and the other 2 are for the bottom side of the manifold in the center. I think the factory ones are too long.
Had a difficult time with accessing the bottom forward bolt where the turbo connects to manifold. I ended up using one of the two supplied hex bolts on the bottom of the manifold.. second bolt in from front.. because I couldn't get a wrench or socket to go around a factory bolt to snug it up. And there was nowhere for me to put the adapter piece the supplied for the coolant line bracket.. so used factory bolt in that location.
Truck definitely drives better and no exhaust leak sound anymore!
When I came back from my test run and let it idle for egts to come down... It wouldn't drop below 350 after a couple of minutes of sitting. Shouldn't drop a little lower? I believe it did beforehand...
Mine takes a RIDICULOUS amount of time to cool down with a stainless manifold. 350* mani temp is cool enough to shut down.
