- Replies 94
- Views 13.4k
Marcus2000monster 46 posts
Mopar1973Man 23 posts
Me78569 21 posts
kzimmer 2 posts
I have said this on a few occasions, but I think the "edge sucking" is not related to the edge. You have said bad things about every tuner you have had in the last month. this makes me think someth
Get a live data tool on the truck, clear codes, take the truck out and drive it hard. You should see boost max out at ~14 psi on the live data tool. If you see more than that then you know the boo
@Mopar1973Man guessing by his screenname his truck is a 00, the map reads correct on a 00 truck using the equation I posted in that link.
I have a issue with my Juice I think. I’m not to concerned about it because I’m getting rid of the edge and going back for another Qaudzilla. So i went to check my wire tap and promptly lost the posi tap piece. Ordered a new one and reconnected it and seems rather slow compared to the first time I tapped it?? Any ideas? No codes or anything. Almost seems like a dead pedal but not really. Definitely has more power than without wire tap though so I lm sure it’s getting fuel. Fuel pressure is 18 at idle and 13 15 wot.
