I am adding a 20" light bar to my 01. I will be making a bracket to add it under my rear hitch, somewhat hidden as much as possible as it is a slim lightbar. Can I run the harness to my non main battery without ill effects? I will be running an inline fuse as well as a relay. My goal is to flip the switch on while backing up to increase my visibility while backing as my reverse lights are not bright at all. Would it work best running from my main battery?
  • Replies 58
  • Views 8.3k
  • Dieselfuture
    Dieselfuture
    Aliens have landed
    I wouldn't make a run all the way to the front again for just battery power being there is a 10 AWG line already back there for the trailer power. It's got a 40 AMP fuse already too. So my reverse lig
  • Dieselfuture
    Dieselfuture
    Just in case, when I put my air compressor in and extra lights for backing up or just to see behind me if I'm in the woods, I ran a piece of pex inside driver side frame as conduit and shoved whatever
You might look at my mod... Two 100 watt aircraft landing lights.
DSCF0561.JPG.e7519a8fa4cd6eedc65b7973aa1
Then I tapped in the reverse switch so that light are automatically on with reverse or manual on a switch.
Thanks Michael. I like that setup. I have already ordered the lightbar, however, if that does not workout, I will for sure copy your setup. Would you advise against running the lights from the secondary battery?
Edited by Red Rambler
I wouldn't make a run all the way to the front again for just battery power being there is a 10 AWG line already back there for the trailer power. It's got a 40 AMP fuse already too. So my reverse light are on a relay tucked in the left side tail light. Powered by the trailer power feed. Triggered by the reverse light lead. Now your wiring is much simpler and less voltage loss from making a long run.
Awesome, did not even think about that. I was concerned in voltage drop with that long of a run. Should be much more simple with that bit of info, thanks again.
Just in case, when I put my air compressor in and extra lights for backing up or just to see behind me if I'm in the woods, I ran a piece of pex inside driver side frame as conduit and shoved whatever wires I needed in there, with few extra for who knows what.
Not a bad idea... I would measure out the PEX and stuff 14/4 trailer wire in the PEX first then run it through the frame with the bed off. Of course do this on the drivers side away from the hot exhaust.
I didn't have to take the bad off just a bit of magic and it went in :thumb1:, maybe little sand in eyes.
  • 4 weeks later...
Any idea what color the 10 AWG wire is?
Edit: red/pink. I found it.
10 AWG? So is one of the trailer plug wires larger gauge than the others wires?
Edited by GSP7
The wire I tapped into was more like 12 AWG. However it had 12 volts, so I know it was the correct wire. None of the wires that ran to the plug were this same wire. It appeared the main 12 was tied into the wires up stream.
8 minutes ago, Mopar1973Man said:
Here you go... Right from the article database.
Exterior Lighting (Page 2) wiring map 1999 Dodge Ram
Pardon my ignorance, what is the path to finding the above article.
10 minutes ago, Mopar1973Man said:
Not a problem...
Thanks, I completely skipped over the Wiring maps and went to the 01 engine wiring maps instead.
So Mike,
Are you running your two 100watt back up lights mounted on your rear axle off that red/org B+ wire from the trailer electric plug?
Id think you would be running a heavier gauge wire direct from your battery ?
1 minute ago, GSP7 said:
So Mike,
Why? You've already got a 40 Amp circuit right there at the rear bumper. I used a relay to trigger the power to the lights. My relay is hidden in the driver side tail light area to keep the relay dry.
This is how I did mine following Mike's advice.
Get a weatherproof relay as well.
8 minutes ago, GSP7 said:
So Mike,
So the answer is Yes?
12 minutes ago, GSP7 said:
So Mike,
Yes...
Where did you buy your 40amp water proof relay ?
Walmart? Specialty Electronics store?
Edited by GSP7
; ipsSettings['maxImageDimensions'] = { width: 1600, height: 1600 }; const ipsJsFileMap = [];
