- Replies 10
- Views 5.6k
Waydin_Stewart 5 posts
Me78569 3 posts
Mopar1973Man 2 posts
Popular Days
If you installed the smarty it now has factory high idle. High idle is built into the "base flash of the smarty" from this point forward you cannot use the Quadzilla high idle. If you do the truck w
@Waydin_Stewart I saw you posting over on Smartresource.com stacking the s03 and the Quadzilla is not support. your issues with the truck shutting off are related to the factory high idle fighting the quadzilla high idle. Again this is not supported. you are going to have nothing but trouble if you stack the 2.
please review the datalogs from the smarty s03 you can accomplish the same "low end torque" using the Quadzilla alone. once you command max fueling, you can't get anymoire "low end grunt" if you want the quadzilla to command max fuel offidle, just psuh your foot to the floor....
Stacking the two will result in nothing but problems.
