I've recently installed a quadzilla adrenaline with BT unit on my 01 dodge. I have 7x10sac injectors, s362 turbo, head studs,  4" exhaust, new vp44, bhaf, fass 150.
I did not wire tap it due to having a new vp44.
First, I'm kinda lost on where to start with adjusting the tune in the quadzilla.
What's safe?
What I can change without wire tap?
I've seen the down loads on this site 1.9.4 (app?) and the 2.7.4(tune?) What are these?
Second, I get a bounce in my fuel pressure gauge (quadzilla kit) by about 5psi (I'll attach a short video), I'm running a petcock in line to the sending unit. With it turned almost close I can limit the bounce to about 1psi... is this normal? Or do I need to get my shovel out and start digging around the fass system.
Thanks for your help!
20171219_180139.mp4
  • Replies 55
  • Views 12.2k
  • Start with this. This is the V2 bible. The Gospel according to Nick.     1psi fluctuation sounds ok to me. If you're worried about it you could probably put a snubber valve before the
On 12/22/2017 at 9:32 AM, Me78569 said:
To start set your fuel load to 2* and your light throttle to 2* tpe reduct to 5* and tps scaling to %50, Then start with
1500:16
2000: 19
2500: 24
3000: 29
max: 30
What did you mean by fuel load 2*, and tpe reduct to 5* and tps scaling to 50%? I don't see these values options in the App.
And Thanks for the reply Ill see if google play has a reader patch app or something.
sorry old names are still stuck in my brain.  Set the top 3 variables in the image like shown.  the light throttle settings work well as well, your truck might want something different.
Alright guys I hate to be the guy that always has problems but I guess it's just my luck.
Here's what I have going.
Samsung Tab A6:
       1. Using 1.9.39 app ( can't update it to 1.9.40 bc it won't load Json files), keeps crashing (black screen or see pic attached)
       2. Won't connect to the adrenaline (If it does see number 1 above, or see pic attached). The Tab A6 Bluetooth see's the Iquad and pairs with it but the app can't find it, or the "Connect to Adrenaline" option is gone. Which I would think means it's paired, but no... all the gauges read zero.
       3. The one time it did connect, It would not load any of the tunes I made, then "unfortunately, Iquad has stopped working".
I decided to load give up on my Tab A6 for a while and try my phone.
Samsung Galaxy S5:
      1. Trouble getting it to connect but finally did after 20mins. Tried to load a custom tune.... wait for it.... All tuning variables failed to update!.... What?!  ( see second attached pic).
      2. See last picture!!!!
Edited by 01dodge24v5.9
Pictures loaded backwards order.
Open the app wihtout connecting to the truck, go into the custom tune menu, select default tune.
Exit the app, go back in.
Try to connect to the truck now.
Once it connects tell us what it reports in the build date field.
you dont have V2 tunes loaded on the box under the hood.  You need to flash the v2 tune or use the version 1.9 vehicle profile.  that's why you are having issues with the tune loading and why the tune doesn't changce.
Edited by Me78569
Do you want v2 tuning?  If so
otherwise if you want to keep running the older v1 tunes just select the 1.9 profile.
Woops, sorry @Me78569 I didn't see that you replied and I can't seem to remove what I just posted.
Edited by kzimmer
Okay flashed it with the new V2.7beta, I'm assuming I need to run the version 2.7 quadzilla test, under vehicle selection?
Here is my first pull at WOT.  For some reason their is a bad dive in the CAN Bus fueling to 2350 at 2887 rpm  ?
Currently running the edge tune on level 3 no wire tap, the red are the things I'm going to change. I get a little haze at cold idle and really no smoke at WOT.
Tell me what you think?
Edge
Number of Power Levels               7
RPM Limit           3200
Valet Mode
Maximum Valet Mode Power      25
Pump Tap Parameters List
Maximum Fuel Stretch   2200
TPS Pump Maximum       100
TPS Pump Minimum        10           0
Min Pump Tap Fueling %              0
Pump Tap Min PSI           0             10
Boost Scaling      30           40
Timing Parameters
Fuel Load Timing              0             2
Low PSI Timing Reduct   4             5
Timing Reduct Scaling     100        50
LightThrottle Timing Adv  4          3
Light Throttle Limit          25           30
Timing Equilzer
1500RPM             15           16
2000RPM             18           19
2500RPM             21           24
3000RPM             24           30
MAX       25
Boost Level Fueling - CAN Bus
0 PSI      80
1 PSI      82.2
2 PSI      84.4
3 PSI      86.6
4 PSI      88.8
5 PSI      91
6 PSI      93.2
7 PSI      95.4
8 PSI      97.6
9 PSI      99.8
10 PSI    102
11 PSI    104.2
12 PSI    106.4
13 PSI    108.6
14 PSI    110.8
15 PSI    113
16 PSI    115.2
18 PSI    119.6
20 PSI    124
22 PSI    128.4
24 PSI    132.8
26 PSI    137.2
28 PSI    141.6
30+ PSI  146
Here's the numbers look at the CAN Bus between 2828 and 2849 RPM ?
Boost    EGT      Load      Fuel psi    RPM    Throttle     Slip      CAN B     Timming
1             473        20           20           745        0             5             781        13.71
1             473        21           20           760        0             5             1160      13.73
1             473        21           20           961        12           19           1346      14.48
1             473        26           17           1169      12           19           1318      16.08
1             490        26           17           1465      20           16           1248      14.65
1             490        30           14           1532      20           16           1252      14.3
1             532        30           14           1550      21           28           1172      14.81
1             532        29           16           1563      21           28           1148      14.87
1             569        29           16           1577      21           30           1166      14.96
1             569        29           18           1583      21           30           1211      14.6
2             600        29           18           1614      22           23           1222      15.58
2             600        29           21           1625      22           23           1191      15.64
2             631        29           21           1652      24           18           1265      15.79
2             631        33           18           1733      24           18           1434      15.69
3             666        33           18           1853      41           22           1634      16.21
3             666        45           16           1989      41           22           2208      17.83
4             727        45           16           2194      70           36           2473      17.89
4             727        62           14           2320      70           36           2627      18.64
5             825        62           14           2564      70           39           3078      20.89
5             825        83           13           2853      70           39           2762      22.99
14           934        83           13           2887      100        42           2350      23.2
14           934        75           12           2849      100        42           3479      22.99
20           980        75           12           2928      100        16           4092      23.44
20           980        100        12           2952      100        16           4095      23.59
36           1028      100        12           2976      100        6             4095      23.74
36           1028      100        12           2975      100        6             4095      23.74
36           1050      100        12           3046      100        9             4095      23.98
36           1050      100        15           3028      100        9             4095      23.94
36           1066      100        15           3047      100        13           4095      23.98
36           1066      100        16           3059      100        13           4095      24.01
36           1072      100        16           3088      100        12           4095      24.06
36           1072      100        16           3105      100        12           4095      24.1
36           1077      100        16           3088      100        11           4095      24.06
36           1077      100        18           3125      100        11           4095      24.14
35           1076      100        18           3079      100        18           4095      24.05
35           1076      100        18           3116      100        18           4095      24.12
36           1074      100        18           3022      100        9             4095      23.93
36           1074      100        19           2988      100        9             4095      23.8
37           1083      100        19           2994      100        2             4095      23.86
37           1083      100        19           2999      100        2             4095      23.89
38           1094      100        19           3000      100        0             4095      23.89
38           1094      100        19           3029      100        0             4095      23.95
36           1103      100        19           3041      97           6             4095      23.97
36           1103      100        22           3023      97           6             1997      23.93
20           1086      100        22           1973      0             8             0            19.26
20           1086      0             18           1935      0             8             1           19.12
10           1000      0             18           1762      0             17           0           19.33
10           1000      2             18           1611      0             17           426        20.07
I would guess you are looking at Torque Management.  If you add MPH to your datalog I am guessing you will see full fueling at ~25 mph.
Edited by Me78569
image.png.c1608b47cb3ea6808294ff8540c2a819.pngThe dark red line is what I'm wondering about see how it falls at line 21.
And the engine load dips kinda wired also from line 22, 23. All at WOT.
Yep I am guessing you are seeing torque management coming into play.  Does this happen above ~30 mph.
